Problem need help
Old Feb 29, 2008 | 07:35 PM
stanglover1250's Avatar
stanglover1250
Default Problem need help
This morning i was going to school and it was sooo freaking cold. While i was driving i notice this ticking sound. It happend everytime i move the streering wheel to the left in a low speed. Everytime the engine is hot or the weather is warm there is no ticking sound. What should be the problem?
Thank you
~sean~
Old Feb 29, 2008 | 09:13 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: Problem need help
Did it go away when the engine warmed up?
Old Feb 29, 2008 | 10:25 PM
stanglover1250
yes, when the engine warms up the sound go away.
Old Mar 1, 2008 | 12:15 AM
Unforgivine's Avatar
Unforgivine
i know my made a whining noise wheni turn mine was just the power steering pump but look at your fluid level and your rack and pin
Old Mar 1, 2008 | 12:31 AM
RyansQuick6
Reverse Gear Member
Mine does ittoo on cold days, I figure it's just the oil being cold and needed to warm up to get in the lifters really good, nothing to freak out over.
Old Mar 2, 2008 | 08:55 AM
ShodanBlackBelt8's Avatar
ShodanBlackBelt8
Yeah mine does it too when the engine is cold, nothing to worry about... i always just wrote it off to be a loose fit somewhere, like maybe a loose gasket that expands when it warms up to close the gap... I would say only check it out if it gets louder, worse, or more frequent... or you start noticing it when it doesn't usually happen.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
