V6 exhaust
Old Oct 22, 2003 | 08:50 PM
Corrupted's Avatar
Corrupted
Default V6 exhaust
is the magnaflow or steeda system considered 'true dual' or is it not? is steeda the same as the borla system? i saw borla warranty mentioned on their page for it.. and from what i've seen borla always sounds great on cars, even the little 2L zx2 i just got out of
Old Oct 22, 2003 | 08:59 PM
hawks05's Avatar
hawks05
Default V6 exhaust
I dont know anything about steeda or borlaor magnaflow i run flowmasters and what i mean by true dual is i have no H-pipe nothing it comes straight out of the engine and straight back</P>
Old Oct 22, 2003 | 09:25 PM
GSRGuy18's Avatar
GSRGuy18
Default V6 exhaust
uh... you're severely misinformed. True duals has nothing to do with having an x-pipe or h-pipe. Most cars with true duals have some sort of crossover. A dual exhaust system that's not "true" has a y-pipe after the cats that goes to one pipe in the muffler and two back out, like the F-body.
Old Oct 22, 2003 | 09:44 PM
hawks05's Avatar
hawks05
Default V6 exhaust
well either way i have neither no X-pipe no H-pipe and no Y-pipe thats true dual<edited><editID>hawks05</editID><editDate>37916.8233449074</editDate></edited>
Old Oct 22, 2003 | 09:47 PM
GSRGuy18's Avatar
GSRGuy18
Default V6 exhaust
are you sure you have NO crossover at all?
Old Oct 22, 2003 | 09:50 PM
hawks05's Avatar
hawks05
Default V6 exhaust
yep positive its a custom setup and i saw it once the guy was done no crossover at all</P>
Old Oct 22, 2003 | 09:52 PM
Corrupted's Avatar
Corrupted
Default V6 exhaust
is that bad for the low end?
Old Oct 22, 2003 | 09:54 PM
hawks05's Avatar
hawks05
Default V6 exhaust
umm not really i lost a little but once i get the pullies i should gain some of it back and the throttle body spacer whill help some too
Old Oct 23, 2003 | 11:42 PM
Tin Kicker's Avatar
Tin Kicker
Default V6 exhaust
HAWKS05, Hot Rod Magazine or Car Craft or somebody did an article way back (hold onto your keyboard) in 1988 on putting a proper crossover in a vehicle. It involved some special high-temp crayons that would melt at (I think) 400 degrees. Probably any really good exhaust shop would know about this.</P>
You drew a line from your header/manifold all the way down your pipes on both sides. Then you cranked the car and let it get hot. The crayons would melt until the point in the pipes where the temperature dropped enough. That point in both pipes was where you installed the crossover. One side might be further toward the motor than the other, but it didn't matter. You installed it THERE.</P>
A crossover balances both sides of the motor and really helps low-end. Something about sonic waves and back-pressure and such (I'm no physicist). Anyway, it's not an expensive thing to add to your car to help your low-end.</P>
baddog671
Jul 26, 2016 01:20 PM
Sep 30, 2015 12:39 PM
junior04
Sep 28, 2015 10:53 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Sep 24, 2015 09:18 PM
