Huge Problem
Old Mar 10, 2008 | 12:23 AM
JamaicanStang04's Avatar
JamaicanStang04
Default Huge Problem
i have a new battery (less than a year old) and and brand new alternator
but for some reason my car die almost every time i turn it off immediately
as i drive, the if i am not on the throttle my battery meter will drop!
i even turn everything off ( radar detector, radio, lights, a/c, everything)
i think it may be my spark plugs or/and spark plug wires
let me know what u guys think
but the way its and automatic
Old Mar 10, 2008 | 01:19 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: Huge Problem
CHeck the connections on the alternator, if it's good then take it back and get a replacement
Old Mar 10, 2008 | 01:46 AM
JamaicanStang04
it was doin it before i put the new alternator on
so i dont think is it
Old Mar 10, 2008 | 05:30 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Check all of your grounds. That has been the problem everytime someone has had any charging issue similar to yours. Check and double check and clean them.
Old Mar 10, 2008 | 01:31 PM
mustangman02232's Avatar
mustangman02232
what kind of battery/ alternator?
corrosion? grounds?
Old Mar 11, 2008 | 03:09 PM
JamaicanStang04
grounds do u mean like around my spark plugs and wires ? where?
Old Mar 12, 2008 | 02:31 PM
projectresto83
M.A.D. Motorsports
Chase the ground from your battery to you frame or block which ever it goes to. Then there should be one from your block to the body. Make sure they are all clea. Check all your wires and make sure there isn't anything broken.
P.S. In your sig, Readar detector is "Radar Detector"
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
