drag springs shocks
Old Mar 12, 2008 | 02:42 PM
Deepenough's Avatar
Deepenough
Default drag springs shocks
Alright well, as of recently i have realized the importance of traction and good launchesin a race and with the mods i've done this winter i feel like some Nitto 555R Extreme DRs in the back along with some drag shocks and maybe an eibach drag launch kit will go a long way. You know they say most races are won in the first 60 feet, and yes i do race on the streets from time to time, nothing rediculousbecause most races wont go past 100km/h anyways.So im asking whatwouldbe a good set-up... i was looking into some lakewood 50/50 shocks in the back but i dont think they make them for my year (2002). Im gonna take off the front sway bar, i have cut springs right now so ive been planning on replacing them anyways, but i heard the drag launch springs raise our cars up higher than stock aha which looks terrible... So any suggestions or set ups would be awesome... thanks
Old Mar 12, 2008 | 03:18 PM
Xemeth's Avatar
Xemeth
Default RE: drag springs shocks
Well, I'm not sure about the V6, but stock rear springs and 4 cyl fox body springs are an awesome cheap setup for the GT's.
For shocks and struts, your best best is an adjustable coil-over setup. If you don't want to go with that trouble, get some Lakewood 90/10 in the front and 50/50 in the back. Look on Summit Racing's site, they had them for 2002 for the GT. I'm pretty sure it's the same.
If you want to go crazy with a suspension setup, I'll list what I'm doing. I know they make all this for the GT, but with an 8.8 rear swap you should be able to use the rear suspension.
Front:
-Sway bar removed
-Tubular front K member with a arms
-Adjustable front coilovers
Rear:
-Full length boxed sub frame connectors
-MM lower control arms with coil-over mounts
-MM torque arm
-ajdustable coil overs
All the rear stuff I listed will work for you if you convert to an 8.8 rear end.
I didn't put down and spring ratings, since I don't feel like going to look for them. If you're looking to get serious about this, talk to the guys at Maximum Motorsports. They're great.
Also, a good suspension setup is better for the track than the street. The street isn't properly prepped for the suspension to have it's full effect. A set of sticky tires will do you fine for little to no track time.
Oh, and street racing sucks.
Old Mar 12, 2008 | 03:28 PM
LilRoush's Avatar
LilRoush
The Lakewoods will fit your car. Go wtih those, and the 4 cyl fox body rear springs for a good cheap set up. Look into a good set of lower control arms as well.
Drag springs won't lift your car at all. Someone was on crack.
baddog671
Jul 26, 2016 01:20 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
mungodrums
Sep 28, 2015 10:54 PM
