Installing a power trunk release.
Old Mar 24, 2008 | 08:38 PM
97 Mustang's Avatar
97 Mustang
Default Installing a power trunk release.
My car did not have a trunk release when I first bought it and I was trying to put one in and I hooked one end to ground and the other to power from a button and nothing happens! there is 12 volts at the wire at the solonoid and if I hook up the solonoid direct to the battery it will pop open the trunk. What am I doing wrong? Do I Need a relay or something else? I have good connection to the wiring and the ground. Is 18 guage wire heavy enough?
Old Mar 24, 2008 | 08:56 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: Installing a power trunk release.
switch the polarity, maybe that's the issue. Find any mustang or lincoln and get the trunk release button out of the glove box, then hook it up using that, it'll look a lot cleaner.
Old Mar 24, 2008 | 09:13 PM
97 Mustang's Avatar
97 Mustang
I tried reversing the polarity and nothing happens
Old Mar 24, 2008 | 09:17 PM
97 Mustang's Avatar
97 Mustang
I tried reversing the polarity and nothing happens!!
Old Mar 24, 2008 | 09:47 PM
RyansQuick6
Reverse Gear Member
check your ground.
Old Mar 24, 2008 | 10:06 PM
JKs95stang's Avatar
JKs95stang
Yup, if it's good directly from the battery (positive), has to be the ground.
Old Mar 24, 2008 | 10:09 PM
97 Mustang's Avatar
97 Mustang
I'm pertty sure the ground is good
Old Mar 24, 2008 | 10:26 PM
JKs95stang's Avatar
JKs95stang
Where did you ground the wire? Tell me not to the tail light assembly!!
Old Mar 24, 2008 | 11:03 PM
97 Mustang's Avatar
97 Mustang
I grounded it to the trunk latch but I'm not surethis was not the best place to ground it. Where would be the best place?
djbigskrilla
Sep 20, 2022 01:04 AM
Granatelli Sales
Jan 20, 2020 12:34 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
SYNY5TER
Sep 2, 2015 01:35 AM
kdryan
Aug 21, 2015 04:01 PM
