Subframe Connectors
Old Apr 1, 2008 | 11:22 PM
02sixbanger's Avatar
02sixbanger
Default Subframe Connectors
Hey guys,
I waslooking through rpmoutlet.com and found this subframe connector setup....http://www.rpmoutlet.com/musv6matrix.htm#1. I was just wondering, what all will this really do? Does it improve handleing? If so how much? Do any of you have it? Any feedback would be great.
Thanks, Mike
Old Apr 1, 2008 | 11:28 PM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: Subframe Connectors
I do believe that site is on the **** list for their order accuracy, service, etc..
Old Apr 1, 2008 | 11:29 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
here, this is what it will do;
http://www.ripoffreport.com/reports/...Off0250435.htm
http://www.resellerratings.com/store/RPM_Outlet
http://www.ford-trucks.com/forums/22...-problems.html
http://www.tundrasolutions.com/forum...id-rpm-outlet/
Old Apr 2, 2008 | 10:55 AM
02sixbanger
Well im deffinatly not going to buy through these guys. Thanks for the help. Back to the original question, what is the purpose of Subframe connectors?
Thanks, Mike
Old Apr 2, 2008 | 11:43 AM
jthorn9's Avatar
jthorn9
The Godfather
Here is what they do as described by Steeda:
Subframe Connectors strengthen the body structure, reducing body twist and tying the suspension together
In short, they're only good for high powered drag cars that make so much power than the subframe bends to a degree where performance is compromised, they can also be used on auto crossing applications to reduce frame twisting in the corners which will help reduce oversteer, however, this gain is marginal at best.
Old Apr 2, 2008 | 06:23 PM
02sixbanger
Thanks for the quick response.
jwog666
Dec 27, 2021 08:09 PM
guitarman376
Oct 11, 2015 01:47 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sep 16, 2015 07:53 PM
TfcCDR
Sep 14, 2015 12:08 PM
