about using SEAFOAM
Old Apr 8, 2008 | 03:58 PM
alfredov6's Avatar
alfredov6
Default about using SEAFOAM
what are ur guys opinions bout this stuff?
i just changed the oil in my car yesterday but i want to seafoam my car to see if my engine ticking goes away
but i heard i got to change the oil shortly after using seafoam.. is this true??
Old Apr 8, 2008 | 04:32 PM
indisposible_teens's Avatar
indisposible_teens
Default RE: about using SEAFOAM
You usually run the seafoam through your car for about 10 miles and then change the oil. Or at least that is how I doit. lol It really helps the engine out. I did it in mine last time I changed the oil and it helped out quite a bit.
Old Apr 8, 2008 | 04:38 PM
v6stang07's Avatar
v6stang07
i usually run the seafoam for 50-100 miles and then change out the oil
i love the stuff but you will want to wait till ur next oil change
Old Apr 8, 2008 | 04:52 PM
mustangman02232's Avatar
mustangman02232
+1 to all the above, wait till your next oil change 1/3 in the crank case, brake booster, and fuel tank
Old Apr 8, 2008 | 07:18 PM
ayrton02's Avatar
ayrton02
Here's the best write up I've found on how to use seafoam. It maybe on a ls1 forum, but the procedure is essentially the same.
http://www.ls1tech.com/forums/showth...hlight=seafoam
I personally use one full can ina FULL gas tank (as I'm filling up to mix it as well), 1/2 can in the oil, and 1/3 can in the vacuum line. Just read the back of the can b4 you buy it and use theiramounts. My car is relatively well kept and it's only got 63k mi so I didn't get alot of smoke, but it runs smoother and I still get the average of 20 mpg in the city with a heavy foot(no change).
Old Apr 8, 2008 | 07:55 PM
alfredov6's Avatar
alfredov6
where would i put it in if i wanted to clean the lifters and valves? the oil or in the brake booster?
can i just 2/3 in the tank and 1/3 in the brake booster for now? till its time for my next oil change?
jpplaw
Mar 19, 2025 08:53 AM
Shadow7874
Sep 24, 2015 09:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
SXGT
13
Nov 15, 2006 02:59 AM
pallidamors
12
Sep 17, 2006 07:41 PM
