Cali Guys Help
This is all you need to do.
Find a stock H-pipe from a 1994 or 1995 Cobra and have a shop modify the flanges to fit the stock manifolds.
My 95' GT BBK X-pipe was modified for $70 dollars.
You should also be able to use any 96-04 GT factory catted H-pipes.
You can find stock ones that people are selling for under $400 dollars and somtimes really cheap.
Bassani sells CA legal cats for $80 each I think.
Also if I remember correctly, you only need two cats (Between the O2 sensors, not behind the rear two.)
ORIGINAL: NeoTokyo
Also, your fuel pump going bad will NOT cause your cats to go bad.
