lt's
Old May 11, 2008 | 08:49 PM
The Yellow Pinto
Guest
Posts: n/a
Default RE: lt's
ok, i googled it (google is your friend, children), and I am nor familiar with air injection...but anyone know if the 98 v6s came equipped with this smog system, or was it just the new edges?
Old May 11, 2008 | 09:54 PM
skidawgz's Avatar
skidawgz
Default RE: lt's
ORIGINAL: RyansQuick6
IF yours didn't come with the bolts, then you should have called them. Hell I would have called them if the flange was bent. You're supposed to remove the studs and use the supplied bolts.
MAC's aren't perfect, mainly because of MAC, but they are the best thing out there. They've left hardware out of my stuff, but they overnight it when I call them and tell them.
i just learned something, thanks.
gonna fix that in a few days
Old May 11, 2008 | 10:27 PM
Clif Brohn's Avatar
Clif Brohn
Default RE: lt's
I'm excited to see how the pacesetter LTs do, all of the PS exhaust pieces i've seen for V8 mustangs and camaros has been good. Hoping they dont skimp on the buzzin' half dozen stuff.
Old May 12, 2008 | 05:24 PM
The Yellow Pinto
Guest
Posts: n/a
Default RE: lt's
anyone know about the air injection?
Old May 12, 2008 | 09:53 PM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: lt's
ORIGINAL: skidawgz
IMO the studs are better, the bolts sometimes back out.
Old May 12, 2008 | 10:30 PM
ayrton02's Avatar
ayrton02
Default RE: lt's
ORIGINAL: l_shizzle_l
ORIGINAL: skidawgz
Yep, I just reused the old studs as well, no problems at all here.
Old May 13, 2008 | 11:29 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: lt's
If you torque them down then they don't back out. I've put 30k mi on mine with no issues.
Old May 13, 2008 | 11:55 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: lt's
Air injection was used for Mustangs sold in Cal. Air injection is nothing more than a few nipples on each tube of the headers that feed clean air into the headers improving imissions quality. In other words, if each of your header tubes have nipples with lines feeding into them, you have air injection, if all you have is plain tubes with the EGR system connecting to your lower half of your passenger side header, you don't.
Old May 13, 2008 | 12:19 PM
The Yellow Pinto
Guest
Posts: n/a
Default RE: lt's
you the man, jthorn. i may consider the pacesetters, then, when they finally come out. thanks!
Old May 13, 2008 | 05:46 PM
mustangman02232's Avatar
mustangman02232
Default RE: lt's
ive got MAC and havent had a problem, only thing i had to get was new gaskets, cause i didnt want to reuse the old ones
