prob with engine light
Old Apr 26, 2005 | 09:59 PM
blackstang06's Avatar
blackstang06
Default prob with engine light
ok this afternoon i changed the spark plugs in my 97 v6 3.8l mustang and the check engine light wont turn off now
however i put champion plugs in it and i completely removed my air intake but was v ery carfull with the inlets i covered them both up. so if anyone has any idea why it is doing this please help me out
Old Apr 26, 2005 | 10:17 PM
Chanedeezy4106's Avatar
Chanedeezy4106
Default RE: prob with engine light
I am not 100% sure on this but I believe you have to goto Ford or a shop and have them hook up a computer to your computer and they shut it off...
Old Apr 26, 2005 | 10:25 PM
blackstang06
thanks ill loke into that
Old Apr 26, 2005 | 11:33 PM
Jimmz's Avatar
Jimmz
Well you can take it to ford and have them look at it which will sot you $$$ they charged me 100 bucks one time to check the steering. Or you can just unhook the negative side of your battery for 10 minutes and it will reset everything and the engine light will come off for sure!
Old Apr 27, 2005 | 12:36 AM
Chanedeezy4106
Awww i've never hear of that before I might have to try that i got a airbag and check engine light on
Old Apr 27, 2005 | 01:55 AM
ZachW04Stang's Avatar
ZachW04Stang
The air bag light won't go away by removing the negative cable but the check engine light will. If theres still a problem though the check engine light will come back on. I don't know what the rules are in the state your in but you won't pass inspection here in maryland with the air bag light on.
Old Apr 27, 2005 | 09:13 AM
The Great Cornholio's Avatar
The Great Cornholio
I ♥ Acer
ORIGINAL: Chanedeezy4106
Also if you know anyone with a Diablo or Superchips hand held tuner you can use it to read the codes and clear them.
Old Apr 27, 2005 | 01:21 PM
PipsBlackStang's Avatar
PipsBlackStang
Why is your airbag light on? Just asking because if it is because of a wreck putting in that new dash computer for the bags will suck. Its not fun. [sm=bangbang.gif]
Old Apr 27, 2005 | 09:03 PM
sarahsmustang's Avatar
sarahsmustang
Just take the car to Autozone, or Advance auto parts. They will hook up to the obdII under the dash and read the codes for you. They will even print out the codes, and recommend what parts are needed to correct it.
tas
Old Apr 28, 2005 | 01:46 AM
steve_mustang89's Avatar
steve_mustang89
you can also get little cheap code readers at wal-mart or other stores with a large auto section. their cheap and you can only get the error codes with them, but then you can find out whats wrong and reset them with that as well
