bushing help
Old Jun 4, 2008 | 11:12 PM
fast stang15's Avatar
fast stang15
Default bushing help
Today i was under my car picking up a socket i dropped and i happened to look at my tires and the inside closest 2 the car is bald on both sides. Can anyone tell me what the problem is? And where can i get the part 2 fix it?
Old Jun 5, 2008 | 04:34 AM
tweak04's Avatar
tweak04
Default RE: bushing help
front tires right? have you lowered the car? if so did you have the camber corrected? is your car pulling at all? bad bushing would make the car feel loose more then wear your tires. i would have the alignment done and go from there. but check all your bushings just in case. anything is possible.
Old Jun 5, 2008 | 08:52 AM
fast stang15
I have not lowered my car (yet). i think its a bushing. the top part of the tire is leaning inward and the bottom is leaning outward.
Old Jun 5, 2008 | 09:01 AM
The Yellow Pinto
Guest
Posts: n/a
an alignment rack should be able to tell you what you need to know.
Old Jun 5, 2008 | 11:14 AM
fast stang15
thanks 4 all the help. Any more advice would be appreciated.
Old Jun 5, 2008 | 04:25 PM
JKs95stang's Avatar
JKs95stang
ORIGINAL: fast stang15
It sounds like a worn outter tie rod to me, fairly common problem with mustangs. It also could be out of alignment. Did you hit any BIG potholes, curbs, islands, etc...?
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Explosive
Oct 2, 2015 07:45 AM
UrS4
Sep 30, 2015 10:13 AM
Sep 16, 2015 07:53 PM
