what does it take
ORIGINAL: YAYITSJEWDAY87
if your mechanically inclined why would you ask what consist of a tuneup that is basic of the basics but plugs wires coil if needed pcv air filter fuel filter fuel injection cleaner belt and recharge battery is what i do
and guess what i can admit it
why post iif you have nothing to contribute
ORIGINAL: El33tist
hm. then how come when i got a tune up done at econolube they had some electronic thing plugged in under my driver's side dash for like 30 mins?
Matthew
At those miles I would definetly add a few extras to the plugs, wires, type tune-up:
1. Fuel Filter
2. Run good Injector cleaner and fuel system cleaner (after changing filter)
3. Check Brake Pads, Rotors turned (Very Simple)
4. PCV Valve (couple bucks)
5. I would probably be looking to change Shocks/Struts
6. ENGINE COOLANT FLUSH!!!
7. Differential Lubricant Change
8. Would also look at Tie Rods/Balljoints (raise vehicle move tires back and forth/up and down should be no play)
9. And syphon brake fluid out of master cylinder and replace with fresh brake fluid.
And dude I promise you can take this list and get all the parts and do it yourself for $100-200 bux!
Also a $16 Haynes manual at autozone is a lifesaver.
1. Fuel Filter
