whats the difference
Old Apr 30, 2005 | 10:40 PM
white_snake's Avatar
white_snake
Default whats the difference
ok i hope this doesnt sound to stupid but, what is the difference between:
1:turbo chargers
2:super chargers
3:blowers
and what is better?
cheaper?
thanks
Old Apr 30, 2005 | 10:56 PM
aamilo's Avatar
aamilo
Default RE: whats the difference
No stupid questions brother, if you don't ask, how do you know.
All refer to forcing air into the engine.
Superchargers us a turbine run with a belt
Turbo chargers us a turbine driven by exaust gas
Blower usually refer to turbo's but can be slang for any forced air system.
Because Turbo charges run on gas they tend not to get up to speed until the engine is at higher RPM's thus there is "lag" while you wait for the engine to spin high enough to spin the turbine to force the air. In a supercharger the turbine is spinning all the time because the turbine is spinning with the engine and thus power is more consistant AND is avaliable at all RPM's. However my understanding is that modern technology has eliminated much if not all turbo lag so there is little difference between the two. I believe cost is about the same between the two my choice however would be the supercharger.
Old Apr 30, 2005 | 11:00 PM
Magiarn71's Avatar
Magiarn71
I've always known a blower as a SC.
Old Apr 30, 2005 | 11:03 PM
Jugador's Avatar
Jugador
yeah blower generally refers to superchargers
white_snake
ok so if i can ever save up the money, what would be the best bet for a 2003 3.8? all my friends say get a V8 but i save alot more gas running a V6.
thanks again
Old Apr 30, 2005 | 11:22 PM
FoxGT's Avatar
FoxGT
The only stupid question is a question not asked.
Turbochargers: They are exhaust drivin turbines. They are more efficient than superchargers in most cases at mid-high rpm, but can be more efficient at low rpm. If you want high rpm power, this is the way to go, turbochargers anihalate superchargers in high rpm power. A turbocharged engine will also get better gas milage than a supercharged car of the same specs.
Superchargers come in 3 varieties:
1. Centrifugal: These are the easiest on the engine & offer the most high rpm horsepower, but lack the ability to produce boost in low rpm. The high rpm power is still lower than what the turbocharger produces at high rpm. Very efficient
2. Roots: These superchargers are the least efficient of the three. They produce the most power in low rpm, but they are horrible at producing mid - high rpm power. They also generate lots of heat. Stay away from these.
3. Twin-Screw: These are the best superchargers for all around power. They produce power from low to high rpm. Not as much low end power as the roots, but very close & not as much high rpm power as the centrifugal. Pretty efficient.
A blower refers to a supercharger. A blower is actully the roots type supercharger, but people often call all types of superchargers blowers.
Superchargers are cheaper. Twin screws are pretty expensive. Single turbo kits are priced allright, but I don't believe in single turboing a twin bank engine. Twin turbo kits usually are the most expensive.
Old Apr 30, 2005 | 11:31 PM
white_snake
so a Twin-Screw supercharger is the way to go?
ORIGINAL: FoxGT
best all round preformance and cheaper than a TT..right.....
Old May 1, 2005 | 01:52 AM
Obselite's Avatar
Obselite
roots aren't THAT bad...i mean gosh
you totally slammed them
twin is the way to go.
centrifugal ones perform awesome, but look gay as hell! lol IMO
Old May 1, 2005 | 04:03 AM
dan's Avatar
dan
also turbos are usually more money but generally yeild more HP. These babys can run quite expensive (can be around 3000 give or take a thousand or 2) which is why they call nitrous the poor man's super/turbo charger. Becasue it can give you 100 extra HP on a nearly stock engine for only 500 bucks. Just letting you know these things can be expensive and there are other options easier on your wallet.
Old May 1, 2005 | 05:11 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
ORIGINAL: aamilo
no they don't. turbos run off exhaust heat. the air pressure keeps them spooled. trust me, that is my job
