Idling Question
Old Jun 26, 2008 | 06:42 PM
kahaj's Avatar
kahaj
Default Idling Question
How many RPM's should a stock 1995 3.8 idle at? I want to be sure that mine's not too high.
Old Jun 26, 2008 | 06:44 PM
JKs95stang's Avatar
JKs95stang
Default RE: Idling Question
ORIGINAL: kahaj
Right about 800 RPM's!!
Old Jun 26, 2008 | 06:57 PM
kahaj's Avatar
kahaj
Okay, mine's at 1100. I guess I need to set mine down a bit then.
Old Jun 26, 2008 | 07:03 PM
JKs95stang's Avatar
JKs95stang
ORIGINAL: kahaj
It will idle that high on a cold start for a little while, it should idle down to 800 after a minute or so.
Old Jun 26, 2008 | 07:43 PM
kahaj's Avatar
kahaj
That's where it's at with the engine warm.
Old Jun 26, 2008 | 08:02 PM
JKs95stang's Avatar
JKs95stang
ORIGINAL: kahaj
Yeah, that's a bit high, your IAC might be getting bad. If it gets worse, swap the Idle Air Control on the throttle body, easy fix, there like 75 bucks!! GL
Old Jun 26, 2008 | 08:25 PM
The Yellow Pinto
Guest
Posts: n/a
^^^ jk is right, most of the time, it is the iac. however, you can check to see how dirty your throttle plate may be around the tb...if its really dirty (ive seen them that dirty), your butterfly could be a hair open, and it could cause the not-so-good idle. try taking apart your intake tract, clean your maf with some electronics celaner, clean the inside of the tb real well, see if that improves the idle.
Old Jun 26, 2008 | 09:47 PM
kahaj's Avatar
kahaj
Alright, thanks for the tips guys.
Old Jun 26, 2008 | 09:49 PM
JKs95stang's Avatar
JKs95stang
ORIGINAL: songtradingusa
Yeah, cleaning the TB is worth a shot, I believe you can clean the IAC too(didn't fix mine on my 95 but my idle was over 2k so it was pretty much a no brainer). I would clean the IAC, TB first, if that doesn't work, go with cleaning the MAF as suggested by SongTradingUSA!!
2007StangV6
Jan 28, 2016 06:09 PM
trashxtrash
Sep 20, 2015 10:49 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
96stang3.8
Sep 10, 2015 06:42 AM
