Brake problem!
Old Jun 27, 2008 | 02:19 PM
RedStarBelgrade's Avatar
RedStarBelgrade
BEWARE OF THIS SELLER. He will sell you junk and call you an idiot for falling for it. Know what you are buying! Admin
Default Brake problem!
Ok, couple of months ago I replaced my front rotors and pads. Now my front right brake begins to squel again. What could that be?
Old Jun 27, 2008 | 02:52 PM
The Yellow Pinto
Guest
Posts: n/a
Default RE: Brake problem!
could be the caliper sticking. are they your oem claipers? if so, and you gotta replace em, time for an upgrade!
Old Jun 27, 2008 | 02:58 PM
RedStarBelgrade
Yeah man they are oem, and I just painted them! And they are not really cheap new!
Old Jun 27, 2008 | 03:14 PM
The Yellow Pinto
Guest
Posts: n/a
^^^ yeah, i know, calipers are never cheap. hopefully thats not the problem, but it sounds like it just may be.
Old Jun 27, 2008 | 03:31 PM
RedStarBelgrade
Well I don't knowwhat else, the rotors and pads are new. Maybe something about the wires, but that just don't make sence! Gotta be calipers, but I'll pass on them for now, maybe next spring...unless it gets really bad!
Old Jun 27, 2008 | 07:33 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Did you seat them properly? they may have glazed over
Old Jun 28, 2008 | 12:34 AM
.boB's Avatar
.boB
Brake squeal is usually caused by the pad vibrating in the caliper. That's why you generally only hear it with light to moderate braking. Ceramic pads also squeal, but at such a high frequency we can't hear it.
Remove the outboard pad. Clean the back of the pad and the caliper finger well with a wire brush and some brake parts cleaner. Apply a liitle Permatex "Disc Brake Anti-Squeal" to the contact area. It's a blue goo, almost like glue. Re-assemble. Press the brak pedal lightly; just enough to seat the pads. Let the car sit over night. That should fix it for about $3.
I used to drive a Dodge Ram truck that needed this treatment about once a year.
Old Jun 29, 2008 | 12:27 AM
Fink's Avatar
Fink
you could also bend the squealer back on the brakes.. you get extra miles outta the pads by doing this also
Old Jun 29, 2008 | 02:35 AM
RedStarBelgrade
ORIGINAL: Fink
How do you do that?
Old Jun 29, 2008 | 03:17 AM
quiksilver00's Avatar
quiksilver00
i wish i had advice but i have the same exact problem so people, help us out!
Tivo304
Aug 28, 2023 12:19 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
musnicki
Sep 23, 2015 07:11 AM
