Fuel pump
Old Jul 5, 2008 | 07:44 PM
CaptainThumper's Avatar
CaptainThumper
Default Fuel pump
So i will be replacing my fuel pump tomorrow and can't find any tech articles or any sort of information to help guide me threw the process
any input is appreciated
thanks
Old Jul 5, 2008 | 10:32 PM
HotRod8515's Avatar
HotRod8515
Default RE: Fuel pump
buy a haynes manual from autozone for 16 bux..best investment i ever made....every single thing you can think of they tell you how step by step and with pictures.
Old Jul 5, 2008 | 11:52 PM
Fink's Avatar
Fink
make sure that your fuel tank as little to no gas in it.. the pump is located inside your tank so you have to take the tank out and change it with the tank on the ground
Old Jul 6, 2008 | 04:33 AM
HotRod8515's Avatar
HotRod8515
have u been in accident or hit anything??? Try your fuel pump shut off reset button located in your trunk to the right behind carpet....lot of people wreck or it switches the relay and shuts off your fuel in case of car accident..and they spend forever and several hundred dollars later replacing everything fuel related.
Old Jul 6, 2008 | 12:47 PM
CaptainThumper
ORIGINAL: HotRod8515
No crash, and i tried the fuel pump shut off reset button several times.
the car will start but once i push the gas the engine shakes real bad and dies im guess not enough fuel to much air..
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
