Rear Window Louves
Old 07-24-2008, 12:40 AM
Scrfc69
Scrfc69's Avatar
Default Rear Window Louves
Anyone have the rear window louves? I"m going to buy one but i have seen aluminum and abs plastic. Which one is better also i have seen some that have hinges and 3m tape and i dont think the 3m tape will stay one at hight speeds but who knows. SO looking for input
Scrfc69 is offline
Old 07-24-2008, 08:02 AM
AmericanMustang07
AmericanMustang07's Avatar
Default RE: Rear Window Louves
I have them on my car....Mine actually came with 3m tape and three 'clips' (not sure exactly what they are called). Basically you would 3m tape it and then clip them in to be more secure.
I have gone on some long trips and steadily went about 90-95mph most of the way and haven't had any issues.
I say go for it! easy thing to add for relatively cheap cost.
AmericanMustang07 is offline
Old 07-24-2008, 08:12 AM
ROCKET32
ROCKET32's Avatar
I have Cervini's aluminum rear window louvers and I have not had any problems. The only issue I had, and this was just something I thought would help, was before I put them on, i bent it just a little more to shape to the window better, then stuck them up there no problems (had them on a year).
Also, they clip at the bottom so you can unclip them to clean the window underneath. Others have asked me if I could even see out the back: yes, it is no problem at all.
ROCKET32 is offline
Old 07-24-2008, 12:38 PM
mcfarway
mcfarway's Avatar
I have Visus louvers & would recommend them ... my only problem was getting the rear window completely clean so the 3M tape would adhere properly (I had to repeat this more than once). I've had louvers on older Fox-body cars & truly appreciate their help in keeping the interior cool(er). I have only used alluminum louvers, so I can't speak to the ABS ones. Personal preference, I assume ...
mcfarway is offline
Old 07-24-2008, 12:40 PM
RoBDoG
RoBDoG's Avatar
Just foudn the site and thinking of getting it real soon. I like that added touch to it
RoBDoG is offline
Old 07-24-2008, 08:05 PM
pythonsweb32
pythonsweb32's Avatar
ape works great and does stay on a HIGH speed :> try california mustang
pythonsweb32 is offline
67LimeCoupe
09-30-2015 04:46 PM
DreadPirateRoberts
09-26-2015 02:11 PM
wishinsky
09-21-2015 09:48 AM
09-16-2015 07:53 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Rear Window Louves
