WINDOW HELP
Old Aug 5, 2008 | 07:34 PM
slick66stang's Avatar
slick66stang
Default WINDOW HELP
i just bought a 02 mustang coupe 2 months ago so i can restore my 66. i had my #3 plug fowl on me and replaced all the plugs. now my battery light comes on and my driver window does not roll up. i have changed the switches and im getting power to the switch as well as all the fuses. im thinking my motor went out on me. this is my first modern car and i need help bad any ideas or suggestions ould ge greatly appreciated.
Old Aug 5, 2008 | 07:45 PM
Xemeth's Avatar
Xemeth
Default RE: WINDOW HELP
See if the motor is getting power. Pop off the door panel, plug the window switches back in, disconnect the connector from the power window motor. Then turn the key on, put a test light to the terminals on the connector for the motor, and operate the window with the switches. If the test light lights, then you have power and your motor has taken a **** on you.
Old Aug 5, 2008 | 07:50 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Pfft
Just hit the spot where the window motor is kinda hard 4 times and say "mustangforums rule" while doing it..
It should start working (and i'm being dead serious)
Old Aug 5, 2008 | 09:44 PM
SuPa StaLLiOn 7's Avatar
SuPa StaLLiOn 7
ORIGINAL: VCS_SSSTANG
Pfft
I don't know about the "mustangforums rule" part but hitting the spot where the motor is definitely works. When I put my window down i make sure it doesn't go down all the way.
Old Aug 6, 2008 | 11:14 PM
SonnyYelow's Avatar
SonnyYelow
Worked for me today...even without the chant, thanks!
Old Aug 6, 2008 | 11:55 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
My painter had the same problem, I told him to whack the **** out of it, and it went right up lol.
Old Aug 8, 2008 | 06:09 PM
slick66stang
yeah the hitting it doesnt work cause i beat the crap out of it last night and still nothing. how do i get the motor out?
Old Aug 8, 2008 | 08:44 PM
RyansQuick6
Reverse Gear Member
You're supposed to hold the up button while you hit it.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
mungodrums
Sep 22, 2015 08:36 PM
wishinsky
Sep 21, 2015 09:48 AM
