Insert removal help
Old Aug 5, 2008 | 08:03 PM
Brenda1's Avatar
Brenda1
Default Insert removal help
Hi Guys! You know the plastic inserts that go in the hood scoop and the side scoops? Well, I want to remove them and paint them semi gloss black. Does anyone know how to remove these pieces properly? Thanks!
Old Aug 5, 2008 | 11:36 PM
Vovovovan's Avatar
Vovovovan
Default RE: Insert removal help
ithink u need to remove the cover from the inner side of the hood, and it shoud have some bolts or clips
Old Aug 5, 2008 | 11:59 PM
Zach333's Avatar
Zach333
on my 2001 they just pop right off and you can pop them right back on
i did the same thing you just said you are gonna do
Old Aug 6, 2008 | 11:13 AM
Brenda1's Avatar
Brenda1
Mine is a 2001 as well, kewl beans! Were you pleased with the results Zack?
Old Aug 6, 2008 | 02:37 PM
Zach333's Avatar
Zach333
yeah it was pretty good... got rid of that greyish flat look... i did the grille and everything
just use the Krylon high gloss black that sticks to plastics and it works great
Old Aug 6, 2008 | 09:12 PM
PNYXPRESS's Avatar
PNYXPRESS
on the side inserts you have to pop the top part loose first and then slide it up and out cause the bottom has a sort of tab holding it in place.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 16, 2015 07:53 PM
