high idle
Old Sep 2, 2008 | 01:37 PM
richmustang1880's Avatar
richmustang1880
Default high idle
my car idles high now when i start it it idles at 2000 then slowly comes down to about 800-900 but everytime i let off the gas while im driving the rpms dont come down unless i come to a complete stop for a while and the problem is continuous. could this be a bad tps sensor or something else
Old Sep 2, 2008 | 04:13 PM
reaper2022's Avatar
reaper2022
IACV maybe? (That's just my guess anyway)
I assume it's not throwing a CEL?
Old Sep 2, 2008 | 04:14 PM
volcomchester18's Avatar
volcomchester18
TPS might need adjustment
Old Sep 3, 2008 | 01:23 PM
richmustang1880
how do you adjust it?
Old Sep 3, 2008 | 01:27 PM
9BlackOnBlack8's Avatar
9BlackOnBlack8
Probably the iac, clean it or replace, on my 95 v6 it was $50 at autozone
Old Sep 3, 2008 | 01:57 PM
Vovovovan's Avatar
Vovovovan
i don't know how it's called, but it's a black sensor on top of the TB, it regulates the air flow. i paid 100 form mine, but i had my shop install if for me.
Old Sep 3, 2008 | 04:10 PM
JKs95stang's Avatar
JKs95stang
Probably IAC, as mentioned. There cheap and easy to fix. GL
Old Sep 4, 2008 | 12:19 AM
volcomchester18
The IAC is adjustable on the mustang?? Most IAC's are not adjustable, they get carbon build up and cause idle problems, such as low idle and stalling. But high idle can be caused by a out of adjustment tps. Anyways, maybe the mustang is different than other cars i have worked on.
Old Sep 4, 2008 | 12:42 AM
2000Stanglover's Avatar
2000Stanglover
I just wondering when i start my car mine idles high for a little then slowly goes down. Is that normal?
Old Sep 4, 2008 | 05:03 PM
reaper2022's Avatar
reaper2022
^ how high? Most engines idle higher than normal until they reach normal operating temp.
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
Drastang
Sep 30, 2015 03:48 AM
MacSerio
Sep 27, 2015 01:05 PM
