Need some wiring help.
A friend gave me a set of lights to put on my last car ('95 Saturn SW2) and never got around to doing it. They are Halo/Strobe/Driving lights, (i know kinda ricy, but hey, they were free). The problem i'm having is that the switch is broken, the plastic case that it was in is missing so all i have is a little circuit board with 3 LEDs, 2 resistors, and 3 switches.
I'd like to rewire it so that i have a switch for each light type.
The way its wired right now. You have to turn on the Halos then turn on the strobes and/or driving lights.
Attached is a simple diagram of how its wired.
Black - Ground
Red - 12v
Green - Strobe (Control, cap., transformer, what ever it is the strobes plug into it)
Blue - Goes to a Relay for driving lights
Yellow - LEDs
Pink - the laminated circuitry on the board.
Can some one draw me up a digram with a switch for each light? As soon as i find my card reader i can post some shots of the actual circuit board if needed. If you need any other info let me know.
No inspections here so i don't have to have them wired to the headlights.
Black - Ground
Red - 12v
Yellow - LEDs
WTF do you have going on there? Mabey the pics will help.
KISS Keep It Stupid Simple.
*Find a power source, Ignition system (on when keys on, off when keys off) on or otherwise
*One switch for each light or function.
They would use the same ground so... One power wire to the switches, branch that off to as many switches per function, from there to your lights and then to ground. A fusable link on your main power wire is a GOOD idea just incase.
jwog666
Dec 27, 2021 08:09 PM
