Clean engine?
Old Sep 29, 2008 | 03:03 PM
Richbrad08's Avatar
Richbrad08
Default Clean engine?
hi i was wondering do u guys know where i could take my car to get the engine clean or steam clean...i was wondering would the average shop be able to do it?
Old Sep 29, 2008 | 04:05 PM
l_shizzle_l's Avatar
l_shizzle_l
umm, i think the local do-it-yourself carwash has a engine degreser you can buy.
Old Sep 29, 2008 | 04:34 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
pull the engine and paint it
just joking....just spray it down with degreaser
Old Sep 29, 2008 | 07:27 PM
moontang's Avatar
moontang
but cover your air filter and fuseboxes as well as alternator and the such spray it down with water then degreaser then water again someone correct me if im wrong but that will work i've never done it myself but i know people who have
Old Sep 29, 2008 | 07:34 PM
svastano's Avatar
svastano
Find a place where they have hot water and good pressure. Use the degreaser let is sit awhile and blast with the hot water. If you have access to a air compressor then use the air blow gun to dry it off. It will look good!
Old Sep 29, 2008 | 09:16 PM
95redv6stang's Avatar
95redv6stang
List of things needed to be covered?
Thanks.
Old Sep 29, 2008 | 10:02 PM
03sixbanger
Ryan's Backup Mod
heck i dont cover up anything honestly. but that could be why i have a wiring problem. hmmm.....anyways, cover up the fuse box even though it has the cover.and the alternator probably wouldnt hurt either....just to be on the safe side....i mean heck nathan drove his car nonstop with a texas sized hole in his hood and never had problems.....but it doesnt hurt to be safe
Old Sep 30, 2008 | 12:21 AM
eaglecatcher's Avatar
eaglecatcher
I covered up any obvious wire connectors (just because I can), the alternator, unplugged the battery, and the fuse box, and sprayed it down with water, took some degreaser and a toothbrush and went to town, spraying it off every few minutes, otherwise it just dries back on lower in the bay, and then it's harder to get to.
Old Sep 30, 2008 | 09:29 AM
v6procharged's Avatar
v6procharged
what kind of degreaser do yall use?
Old Sep 30, 2008 | 10:39 AM
moontang's Avatar
moontang
simple green works i know as would greased lightning id imagine thats what i use at work and other degreasers of that kind
