Need Help
Old Oct 5, 2008 | 06:51 PM
deykamp's Avatar
deykamp
Unhappy Need Help
Anyone know why my car will not start unless I unhook and hook back up the positive battery cable?
Old Oct 5, 2008 | 06:53 PM
95redv6stang's Avatar
95redv6stang
I would start off by cleaning off your terminals and adding Dielectric grease to the terminal and cable. I would guess corrosion
Old Oct 5, 2008 | 06:55 PM
deykamp's Avatar
deykamp
Default Need Help
The car turns over fine; It just does not fire. Unhooking the battery terminal probably resets the engine control unit. Just curious if anyone has experienced this issue. I have already cleaned the negative and positive battery terminals.
Old Oct 5, 2008 | 07:03 PM
deykamp's Avatar
deykamp
I have already tried that. Do you know of any issues with the control unit, etc.? I believe unhooking the positive terminal resets the control unit
Old Oct 5, 2008 | 07:30 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
is it coming loose?
Old Oct 5, 2008 | 07:56 PM
95redv6stang
Originally Posted by 03sixbanger
is it coming loose?
He explained to me that when he disconnects it and then reconnects it's as if it restets the ECU and starts fine.
Old Oct 5, 2008 | 08:46 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
It has to be disconnected for more than just a second to reset anything. Are there any CEL's?
Old Oct 5, 2008 | 09:50 PM
moontang's Avatar
moontang
dont you mean MILS ryan ;-) and i woudl say check all connections and fuses and relays it just something i woudl do make sure nowhere has any lose wires (you maynot have to go too in deapth just the simple stuff off the fuse boxes and the such) and also check all your connections on you battery leads trace them as best you can see if when you move anything you may have a lose wire
this is just a shot in the dark and where i would start K.I.S.S. FTW
Old Oct 5, 2008 | 10:41 PM
cuban tech's Avatar
cuban tech
no he meant CEL"s as in Check Engine Light. Unless you car has a MIL light.
Old Oct 5, 2008 | 11:25 PM
RyansQuick6
Reverse Gear Member
^ Ooooooooh Buuuuuuurrrrrnnnnnnn, that had to hurt moon lol j/j
