HELPPPPP!!
Old Oct 9, 2008 | 09:23 PM
cuban tech's Avatar
cuban tech
and yes if you take it to a tech they will charge you just to check it out we do at the dealer i work at.
first find out what the code is and go from there
Old Oct 10, 2008 | 11:42 AM
Chromestang67's Avatar
Chromestang67
Default Gotta love the techo
This may help:
1) you can pay a local tech to check it for a fee.
2) go to autozone/pepboys/checker and ask it to be checked or buy the cheapest code reader you can buy around $40-$70 for OBOII vehicles domestics 94-04 Fords.
3) I had a customer who had constant check engine light troubles but different problem, I could not figure out the problem as code reader stated left Bank is lean? So just disconnect the negative/black battery terminal tap it against the battery twice and tighten it back down. See it this helps but this is a temporary fix.
Old Oct 12, 2008 | 04:44 PM
99 v6 mustang's Avatar
99 v6 mustang
Originally Posted by ByPopularDemand
Get the code read have em print up what it says and post it here
alright im going to get them read at auto zone right now lol
Old Oct 12, 2008 | 05:30 PM
99 v6 mustang
Originally Posted by 03sixbanger
have you read the computer with a code reader?
yes i got them today
Old Oct 12, 2008 | 05:37 PM
99 v6 mustang
alright i got the codes...
its more than one..
p0306= cylinder missfire detected cylinder number 6
p0401= EGR system fault (exhaust gas recirculation)
p0303= cylinder miss fire detected cylinder number 3
p0414= secondary air injection system fault
p0411= same as the one above...
ANY ONE HAVE AN IDEA????????
Old Oct 12, 2008 | 08:14 PM
nanaki's Avatar
nanaki
Retired MF Moderator
wow. how long you been driving that thing with the CEL on?
Old Oct 12, 2008 | 08:27 PM
99 v6 mustang
toooo long if its to expensive to fix im getting rid of it
Old Oct 12, 2008 | 09:33 PM
95redv6stang's Avatar
95redv6stang
And if it's too expensive to fix, I'm taking it off his hands Bring on the project. lol.
Old Oct 13, 2008 | 01:34 PM
3.8YOU's Avatar
3.8YOU
The tech you talked to was probably right. A misfire that has been overlooked can cause the cats to fail.
Old Oct 13, 2008 | 08:27 PM
95redv6stang
When I heard it running today, It sounds like it's starting to knock. It is clearly misfiring and the exhaust is way louder than it should used to be, Would that be caused by the cats going out?
I want to try: A full tune-up and Change oil to a 10w-30 Blend (due to HIGH miles) with new filter and see what happens. What do you guys think?
