windstar split port intake
Old Oct 19, 2008 | 06:53 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
As far as I know, you'll need an EGR delete, and need to fab up an intake tube to work, along with something to relocate the IAC. If you have the tools you can biuld your own IAC plate, but I wouldn;t recommend it if you're not well versed in it's operation.
Old Oct 19, 2008 | 06:57 PM
RyansQuick6
Reverse Gear Member
I keep forgetting stuff lol
I also have the windstar fuel rails and windstar EGR bracket, so I think that will allow the intake to fit with no modification to the stock rail, and slight modification to the EGR tube, but I have to actually try it, since nobody else has.
Old Oct 19, 2008 | 07:01 PM
RyansQuick6
Reverse Gear Member
Old Oct 19, 2008 | 07:07 PM
bullet281s's Avatar
bullet281s
can u use the stock throttle body from the mustang or use the windstars?
Old Oct 19, 2008 | 07:32 PM
ramoyer1's Avatar
ramoyer1
OK OK I just made a kit! it can be egr useable you will need the low pofile off the windstarts lower intake.I will post pics of when i did the last to my firends and yes you can feel it.
Here is mine....
and others that have been done
this is the last one i did....
Old Oct 19, 2008 | 07:38 PM
bullet281s's Avatar
bullet281s
lol well i wish i knew where to start.. i am so lost... this is what i have... i have the intake just like in ryans pics and i also have the lower too. that what i have... i am goin back to the junk yard next week is there anythin else i can grab to make this work with out really going out and spending the money for it
Old Oct 19, 2008 | 07:42 PM
ramoyer1's Avatar
ramoyer1
ok if you have the lower there should be a egr mount on it. IS there? if so that is what you need if you wanna run a egr setup. next you are gonning to have to cut the top of your windstar intake off for it to fit under your stock hood and plug the hole for ur air intake conrtol. look at my pics to see what i am talking about after that i can walk you from step to step if you would like! POst pics if you can
ramoyer1's Avatar
ramoyer1
and you can if you have msn messager add me and i can do it in real time
Old Oct 19, 2008 | 08:25 PM
RyansQuick6
Reverse Gear Member
I'm pretty sure you use the mustang tb, since the windstar one is backwards
Old Oct 19, 2008 | 09:48 PM
ramoyer1's Avatar
ramoyer1
yes you have to use ur tb. but you have to fab up a arm for it.It is pretty ez.
your fuel rail will have to be bent a lil that is the unsafe part about the hole thing cause if you go pulling on it too much it can break.
It is pretty ez you make ur own kit.
