you really use that flex hose and trust it to hold your boost? sheesh let alone the ineffiency that all those ridges and curves produce. maybe its just me though
well yes and no. It can but you would have to get a bigger "taller" hood but the gains you be great cause you would have to a spilt-port swap...use search button
ok if you have the lower there should be a egr mount on it. IS there? if so that is what you need if you wanna run a egr setup. next you are gonning to have to cut the top of your windstar intake off for it to fit under your stock hood and plug the hole for ur air intake conrtol. look at my pics to see what i am talking about after that i can walk you from step to step if you would like! POst pics if you can
ok well i dont know what u mean about cutting the intake but i have a 03-04 cobra hood so i dont know if that sits as low as the stock hood but i know this sounds stupid but what does the egr mount look like?
ok the one on the left is the stock 3.8 mustang egr mount.....the one on the right is the one you will need as you can tell it is lower then the stock 3.8
