ECU modification
Old Oct 29, 2008 | 09:30 PM
mustangman99's Avatar
mustangman99
Default ECU modification
I am looking to connect my car's ECU to a computer. I was initially going to buy an OBD-II reader off of ebay, but I found the company Hondata.com installs a usb cable directly to the ecu of some cars for this purpose? Does anyone know of a company that does this for Mustangs?
Thank you all very much.
Old Oct 29, 2008 | 10:18 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
you don't drive a honda, so no it won't work. We use programmers to take care of that stuff, and it's best to be done by someone who is trained to do it. With your mods, I wouldn't recommend going crazy unless you plan to go F/I
Old Oct 30, 2008 | 02:02 PM
mustangman99
I was wondering if there was a similar company that modifies the ECU with a USB cable but specifically for Mustangs. I currently have a macmini built into my car, so as I drive I would like to visualize RPM, HP, Speed as well as other statistics. Once I have that done, I will be using a shop I know in PA to tune my car.
So does anyone know of the name of a company that can do this to a mustang's ECU?
Old Oct 30, 2008 | 02:36 PM
RyansQuick6
Reverse Gear Member
So want a guage cluster, it shows rpm, speed, fuel level, oil pressure, voltage, and coolant temp. SCT makes tuners, with DATALOGGING, this is not a HONDA, things don't work the same, I used to drag race hondas back in the day, before "The Slow and the Curious" ever came out, I know what I'm talking about, just listen.
Old Oct 30, 2008 | 09:28 PM
R1CK3R's Avatar
R1CK3R
My brother got an ecu chip for his VW awhile ago, Obviously its a diff make/model but where would i get a sport chip that increases HP etc.?
Old Oct 30, 2008 | 09:41 PM
moontang's Avatar
moontang
you dont buy "chips" for our cars you buy tunners or programmers to load tunes
Old Oct 31, 2008 | 01:27 AM
RyansQuick6
Reverse Gear Member
Why do I have a feeling that your brother bought his "Chip" off of Ebay, for $19.95 "Buy it now!" and recieved a $0.05 resistor in a pretty little box that he had to splice in to one of his sensors on his intake?
Tell him to enjoy constantly running lean.
Old Oct 31, 2008 | 02:29 AM
cobra232's Avatar
cobra232
Justin Starkey @ www.vmptuning.com
he can custom burn an SCT Xcal for your specific setup. he is the best V6 stang tuner out there
Old Oct 31, 2008 | 09:59 AM
amrcnidyot's Avatar
amrcnidyot
actually you can buy a "chip" for our cars. its just smarter to buy the tuner becuase with the tuner you can change things as many times as you want with ease. with a chip, the new program is programed into the computer and its stuck that way unless you send the chip back to the company you bought it from and have them put a new tune on it.
Old Nov 1, 2008 | 09:08 AM
moontang's Avatar
moontang
well i guess clarifycation should be aplied to my previous statement you can buy ships but its not worth it i wouldnt buy a chip stick with tuners its esier that way
