just thinking
Old Nov 4, 2008 | 01:02 AM
ramoyer1's Avatar
ramoyer1
Default just thinking
Ok say that for some reason you wanted to do a n/a build with a 4.2 block if you bored it over would you get more power out of it?? I am asking because i got a 98 4.2 motor that has bad rings in it. How far can they be bored over before problems happen.I know that 302can go 60 over. but i throw them away at 40 over.
I wanna try it and see what happends plus it get rid of my blown up 3.8 motor too because i can pull the get parts off and junk the rest of it.
If i do build it there will be no power adders (nos,s/c,turbos)just stright up motor.i want to make the most hp that motor can put out
Old Nov 4, 2008 | 01:32 AM
Cryptostorm's Avatar
Cryptostorm
i dont know for sure, but i believe people usually stop at 30 making 4.3
Old Nov 4, 2008 | 06:45 AM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
i believe 60 over was tried and it caused problems
Old Nov 4, 2008 | 10:37 AM
ramoyer1's Avatar
ramoyer1
yea i was thinking 60 over way to much. wat if it was sleaved? then 60 over not might be bad.
4.2 +.60=4.8 nah to much
4.2 +.40=4.6 <---- hehe a v8 displacement
Old Nov 4, 2008 | 01:13 PM
l_shizzle_l's Avatar
l_shizzle_l
No no no. That is so wrong. If you machined .6" or even .4" out of the cylinder walls then there would be nothing left. With my .030" bore I have .31" of cylinder wall left between them(yes I did just measure that lol).
4.2L + .030" bore = 4.265L = rounded up to 4.3L
To make it a True 4.3L you will need a .050" or .060" bore.
The bore is in hundredths of inches(.0X0"), not in tenths.
There is no possible way to make it bigger than a 4.3L with only boring and a 4.2L crank.
Old Nov 4, 2008 | 02:51 PM
LilRoush's Avatar
LilRoush
Never go more than 30 over with the sixer. ANd if you are going N/A, you'll want higher compression as well, so make sure you account for that when chosing pistons.
Old Nov 4, 2008 | 04:01 PM
ramoyer1's Avatar
ramoyer1
ok so does anyone know about how much hoper poer can be made out of a N/a build.Because i did like a lot of ppl and went fi. but my camaro is stright motor and hauls @$$.
could you break the 285hp mark on a n/a build? I am thinking it might just be a lost of money if it didnt get close to 300.
Old Nov 4, 2008 | 04:16 PM
ezekiel90's Avatar
ezekiel90
the safest is keeping the 4.2. any more and you'll gett some serious problems with the cylinder walls being too thin. i might be wrong,but i heard you can get about 50 more rwhp from the stock 3.8 bored to a 4.2 done with all the right things.
Old Nov 5, 2008 | 01:51 AM
ramoyer1's Avatar
ramoyer1
is that all? what does that put it at and does anyone know were to get a hold of high comp. pistons? and rods out of a 351w right?
what about haveing the crank polished?
I am thinking about self porting because it is cheaper.
I need a round about hp rating to see if it is even a good idea
Old Nov 5, 2008 | 08:52 AM
LilRoush's Avatar
LilRoush
Polishing the crank will do nothing.
N/A you can maybe see 265 or 270 hp at the wheels with a VERY good ground up build. (This means not self ported parts.)
My 4.2L in N/A trim made 247 rwhp...but it was low compression, and awaiting the blower set up. Higher compression and a better N/A cam would have done wonders for it.
