Some help from the V6 crowd
Old Nov 25, 2008 | 09:18 AM
  #21
cobra232's Avatar
cobra232
the supersoupe swap will be a damn fine idea. 3.45 gears and a detroit truetrac and it should run high 13's on a stock setup.
they are very good bases to work with. ported heads and open up the ports on the supercoupe intake, weld the silencer ports on the blower for more of that roots whine, cam it and make sure you don't use the GT mufflers on he GT catback. cut them off and get some Thrush 2 chamber (flow 40 knockoffs) for $30/muffler from jegs and it will run and sound damn good.
used 3.45 gears can be found on EBAY for about $50. it's a great gear for the torquey M90 and the speedo will be dead on with the 23 tooth speedo needed to calibrate it. 3.73's wouldn't be bad either.
great place for M90 go fast stuff
www.magnumpowers.com
some of their power recipies. no one can say an M90 setup isn't a good base for making power
http://www.magnumpowers.com/thunder_power_recepies.php
McLeary
Mar 14, 2016 07:50 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Soaring
Oct 8, 2005 04:30 PM
jishead
Jun 9, 2005 03:21 AM
