SCT problem
Old Dec 9, 2008 | 09:13 AM
3.8YOU's Avatar
3.8YOU
Default SCT problem
I have the x3 handheld and I went to tune my car. Plugged it in, program vehicle, install tune, adjust options? yes, pulling up options... And that is as far as it will go the screen just says "pulling up options..." and has never done this before.
Old Dec 9, 2008 | 11:00 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I've noticed that if my Xcal isn't at room temperature or above, it craps out. If I leave it in the car, which I always do, and it's cold outside and try to do anything, it doesn't even make the pretty little startup noise.
Whenever I plan to use it in the cold, I either take it inside for half an hour, or drive with the heater blowing on it on the passenger floor board, and then it works like a champ
Old Dec 9, 2008 | 11:33 AM
my94pony's Avatar
my94pony
my ipod does that, just keep it in the house
Old Dec 9, 2008 | 01:12 PM
3.8YOU's Avatar
3.8YOU
Always coming up with the easiest was to fix things! Considering I opened it in my car and it has not been out since, hopefully that is the problem. Whats the word on your car though?
Old Dec 10, 2008 | 09:08 AM
Justin00Stang's Avatar
Justin00Stang
I've never heard of temp problems, but it certainly could be an issue. You can always check out the support section on www.sctflash.com, they have some pretty in depth archives.
Old Dec 10, 2008 | 09:17 AM
Blivit's Avatar
Blivit
What firmware is currently on this device?
Old Dec 10, 2008 | 11:16 AM
3.8YOU's Avatar
3.8YOU
The temp wasn't the problem. And yeah I've already gotten a hold of someone there but he is taking forever to email me back.
I do not know; whatever came on it brand new, I should probably download the latest updates from the website.
Old Dec 10, 2008 | 11:26 AM
Blivit's Avatar
Blivit
No, not necessarily. You need to know what is on it first before updating it. The revision number is displayed in the device info menu.
Old Dec 11, 2008 | 06:10 PM
3.8YOU's Avatar
3.8YOU
It says it has version 1.1.100 on it.
jma2
Jul 10, 2023 01:00 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
03blackwidow
Sep 20, 2015 02:36 PM
ccdguy
Sep 19, 2015 05:20 PM
kmad61
Tuner Central
Sep 18, 2015 05:02 PM
