CAI help
Old Dec 29, 2008 | 06:43 PM
bstevems39's Avatar
bstevems39
Default CAI help
so seems to me that most people say CAI are the same and to just get the cheapest one. i have a cheap one and was looking to get a better one or would my money be spent better elsewhere?
Old Dec 29, 2008 | 08:07 PM
Fink's Avatar
Fink
spend it somewhere else. your stock intake with a K&N filter and silencer removed provides the same gains.
Old Dec 29, 2008 | 08:11 PM
bstevems39's Avatar
bstevems39
do i need a shield or anything after i remove the silencer?
Old Dec 29, 2008 | 08:15 PM
Fink's Avatar
Fink
No, I dont have one on my car.
Old Dec 30, 2008 | 09:19 AM
bigjj92's Avatar
bigjj92
can i remove the silencer and keep the stock filter
Old Dec 30, 2008 | 10:00 AM
KillJoy's Avatar
KillJoy
Really no advantage..
Old Dec 30, 2008 | 10:11 AM
NeoTokyo's Avatar
NeoTokyo
The best way to do an intake setup (When you need it, stock isnt making really enough power to REQUIRE it) is to build your own.
Your restriction will come at the throttle body where most are limited to a 70mm TB. A windstar intake can be modified to accept a 75mm TB.
The next restriction is the MAF.
MAC makes a very nice 73mm MAF housing as does C&L, they both work very well and is just right for those with 70mm or smaller TB's. Those running a windstar 75mm setup should step up to a 80mm Housing. Accambo makes a nice housing that has a tunable sensor.
Make sure to run the proper diameter tubing as to never restrict flow from the Filter to the MAF to the TB.
A streight shot offers less restriction but requires a box to still keep it a fender intake. You can also just use a cheapo ebay CAI for the plumbing angle that is directed into the fender.
Its pretty easy once you sit down and go over your materials and layout.
For pre-fabbed CAI's you can go wrong with name brand fitment and ease of installation.
MAC's 73mm kit is just over $200 dollars but comes with that 73mm housing.
I have run BBK in the past and still do, its a quality intake system.
-Eric-
Old Dec 30, 2008 | 10:17 AM
NeoTokyo's Avatar
NeoTokyo
I meant you CANT go wrong with name brand.
My stupid browser isnt loading the "edit" button for me to go back and fix it.
Damn IE...
Old Dec 30, 2008 | 12:01 PM
bstevems39's Avatar
bstevems39
thanks for the help
Old Dec 31, 2008 | 12:24 AM
Modular_Madness96's Avatar
Modular_Madness96
spend it on gears
