Heat and AC
Old Jan 1, 2009 | 11:29 PM
sIx's Avatar
sIx
Its really not that bad. When the **** is turned to A/C, it draws in air from Outside the car. Max A/C takes air from inside the car, makes it hotter or colder. When using A/C or Max A/C, your going to get cold air if the **** is turned to the cold or blue side, and heat if its turned to the red, or heat side. When you put your selector on Defrost, it still uses the A/C pump, just directs the air to the windshield.
Either way, A/C or Max A/C is going to de-humidify the air, and thats how it helps the windows not fog up.
Old Jan 2, 2009 | 11:32 AM
Norm Peterson's Avatar
Norm Peterson
Recirculated air apparently cannot be selected for the defrost mode, though the A/C system is automatically engaged.
Originally Posted by Mustang Owner's Guide 2008, Climate Controls, pg 45
To reduce humidity build up inside the cabin, do not drive with the airflow selector in the O (OFF) postion or with recirculated air engaged
boldface mine
Norm
Old Jan 2, 2009 | 11:59 PM
JOE2391's Avatar
JOE2391
ok that solves the problem thanks
PaulH2
20
Jan 31, 2016 09:48 AM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
