Fiberglass or Polyurethane??
Old 01-02-2009, 06:27 AM
Fink
Fink's Avatar
Default Fiberglass or Polyurethane??
Im looking at getting a Cobra R front and I was just wondering whats the difference between fiberglass and polyurethane?? Which is easier to install?? What would you guys prefer??
Fink is offline
Old 01-02-2009, 07:51 AM
MurderedStang
MurderedStang's Avatar
Polyurethane is stronger and more durable, fiberglass will do you fine if your a good driver and can stay out of bad places and not hit little things in/on the road.
MurderedStang is offline
Old 01-02-2009, 08:35 AM
Fink
Fink's Avatar
Yeah cruizinconcepts is having a sale on fiberglass Cobra R fronts. I wanna buy it but I dont know when I can get my car painted. Theres only 1 body shop in my town and I dont wanna have a bumper taking up space in my parents basement.
Fink is offline
Old 01-02-2009, 08:38 AM
ooterman
ooterman's Avatar
Poly is a solid plastic piece that will will crack when hit but is pretty strong. Fiberglass is a material made up of millions of fibers and will crack and fray when hit.
I vote Poly as well, but both will work and unless your going off road spelunking I would not worry about what you picked to much.
ooterman is offline
Old 01-02-2009, 11:03 AM
reaper2022
reaper2022's Avatar
Polyurethane is what most stock bumpers are made of, so that should give you a good idea of their resiliency. Fiberglass bumpers usually don't fit as well, and are easier to break. Still, you shouldn't have to worry about the fiberglass bumper breaking unless you're off-roading in your mustang.
reaper2022 is offline
Old 01-02-2009, 11:18 AM
Fink
Fink's Avatar
Well you know that Mustangs sit a little higher than most sports cars. Hahaha. Well I wont have to worry about that since my car will barely be driven in the summer and its gonna be parked in the winter so I should be good with being able to keep it on road.
Fink is offline
Old 01-02-2009, 11:41 AM
LilRoush
LilRoush's Avatar
DO NOT DO FIBERGLASS. The first time you scrape, you will be buying a new one.
Poly made are MUCH BETTER. My front splitter (well, the whole lower body skirting) is a poly based material. I've hammered the brakes hard enough on the track to grind it in hard several times and it's still going. One time I even ripped it off and drove over it. Got it back and put it on again.
I would never put fiberglass front bumpers on a car. Too cheap of material, too much work to keep looking good, and too much of a chance of destroying it.
LilRoush is offline
Old 01-02-2009, 12:15 PM
Fink
Fink's Avatar
Ok I'll reach a little farther into the pocket and spend it on a quality bumper. Do you guys know anywhere to get OEM skirts? Mine are all messed up for some reason, the corners are all cracked.
Fink is offline
Old 01-02-2009, 12:29 PM
jthorn9
The Godfather
jthorn9's Avatar
Look up on ebay for a used set o OEM skirts, it's going to be hard to find some that aren't too badly scraped, but I'm sure it's possible.
But as stated, stay away from fiberglass. I know you've seen ricers around your town with Fed up front bumpers, well I gurantee you all of them are fiberglass. Only parts that are good in fiberglass are side scoops, wings, and some hood brands, but stay away from it when it needs to go along the bottom of your car.
jthorn9 is offline
Old 01-02-2009, 12:34 PM
HornyHornyHippo
HornyHornyHippo's Avatar
+1, fiberglass is cheaper to
HornyHornyHippo is offline
Quick Reply: Fiberglass or Polyurethane??
