CC alignment specs
Old Jan 9, 2009 | 07:48 PM
winner99's Avatar
winner99
Default CC alignment specs
I just got my MM double adjustable CC plates out on but where can I find or what are the recommended alignment specs? Besides Fords? I will more than likely be joining nasa later.
Old Jan 9, 2009 | 11:16 PM
robinson209's Avatar
robinson209
I'd like to know too!
Old Jan 10, 2009 | 12:08 AM
sransari's Avatar
sransari
depends on what you're trying to do. you should probably keep stock specs (-.5 camber) unless you're road racing and want a little sharper handling around the turns. -1.5 camber and -4 caster or so will let you whip turns a little faster, but will tear up the inside of your tires. use max caster if you're drag racing and want to go straight down the line. I used CC plates to align the car to stock specs after lowering.
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
