Dreaded Mach 460 Issue
like i said earlier, the amps in the 460, all three of them: the one in front for the tweeters and the two in back for all 4 6x8s, are line level input amps. by sending a speaker level output to them, (which nearly every headunit does, so that you can run a speaker without an amp) destroys the amps after a while of time. so im guessing that your rear speakers were running off of the stock amps wired wrongly.
the solution? run your own wires from the head unit to your rear speakers. just like lilroush said.
I'm glad I could provide some humor to your life haystackstang.
Let me reinterate my statement above:
I have no sound at all from the back 6x8 subwoofers, so I replaced them. Nothing happened, still no sound at all. Both pair of tweeters (front and back are original and working), and the front door speakers are working also. NO BASS, NO SOUND from the rear 6x8 subwoofers only, NADA! Tweeters and front speakers have a little bass.
Okay, so all 3 original amps were not connected to anything. The front speakers and tweeters were connected together to the head unit. The fix for the back speakers was to wire them directly to the head unit, although, when that was done the entire system shut down. The back tweeeters were then disconnected and, waa laa, everything worked! So what I have now is, no Mach 460 amps, front door speakers, front Mach 460tweeters, and back speakers only. I would still like more bass though.
rip the whole thing out and start over fresh
mine will be:
Pioneer 5.8” navigations f700bt
MB Quart Dkh 168 6x8 speakers120 (front)
MB Quart DKH 113 5.25” (rear, i have a vert, coupes are 6x8 rear to)
Infinity 1011T tweeters
Profile AP600 amp (2)
JL audio W1 V2 10’ sub 300 rms
Profile AP2000 amp
Steeda Battery relocation
Steeda Battery Box
alternator 200a w/ 4 guage wire
mine will be:
Profile AP2000 amp
Steeda Battery Box
wait a minute mustagmann. I have like legit the same car as you and the guy at bestbuy told me I have 6x8's all around. So i put alpine 6x8's in the front and rear. Is it bad or should I do something about it?
haha yes I understand that. But I bought them from a buddy at bestbuy who gave me a discount so it wasn't "technically" through the store. So they wouldn't replace them on their own. I can check but I'm almost positive they jammed them in there or something.
verts have a 5.25 rears,
