Window replacement
Old Jan 13, 2009 | 01:08 AM
eddiev22's Avatar
eddiev22
Default Window replacement
Parked in NYC tonight and came back to my car to find the drivers side window was all busted and my radar detector/jacket were taken. kind of sucks, but anyway, lots of glass dropped into the door panel.. anyone ever have to deal with anything like this?
gonna remove the panel, shopvac all the glass pieces out, then have to get a new window and seat it on the motor correctly.
Anyone ever do anything like this? Where/How much is a new window anyway?
Complete newb with this subject so any help would be appreciated.
Old Jan 13, 2009 | 10:58 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
It's easy, just pop off your door panel, get all the glass out, roll the track down about half way and you'll see the mounting tabs for the window on the track. Unblot them, and slide in yur new window, bolt it back it and you're all set. It'll probably take you longer to get the glass shards out of the door than it will to replace the window.
When installing it, set the track to where you have the easiest access to the bolts holding the clips in.
Old Jan 13, 2009 | 11:48 AM
eddiev22's Avatar
eddiev22
thanks bro hopefully its as easy as you say, gonna check some junkyards for a window
Old Jan 13, 2009 | 02:13 PM
eddiev22's Avatar
eddiev22
well i got the door panel off but have no idea how to take out the steel guard that is over the whole door restricting my access to the broken glass/motor
Old Jan 13, 2009 | 02:43 PM
alkureg's Avatar
alkureg
ive been wondering how you get behind that too, the power window motor is out on one of my cars and it has the same metal guarding the glass.
also to the OP, hide your ****
Old Jan 15, 2009 | 01:21 AM
eddiev22's Avatar
eddiev22
instead of continuing to try and remove pieces of the door, i dont want to screw it up so im gettin it done by a shop tomorrow.. ill tell you how they do it
Old Jan 15, 2009 | 01:17 PM
RyansQuick6
Reverse Gear Member
you lower the window track with the switch, and there are openings in the door frame to access the bolts, it's really easy.
5.0muscle
Jan 11, 2016 01:17 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Art161
Sep 9, 2015 10:33 AM
