91 regal 3800 v6(wana swap engine
Old Jan 19, 2009 | 10:46 AM
alkureg's Avatar
alkureg
try a buick forum?
Old Jan 19, 2009 | 02:30 PM
mustangman02232's Avatar
mustangman02232
L67 swap?
Old Jan 20, 2009 | 07:04 PM
newpony's Avatar
newpony
whats is a l67
what car is that in
Old Jan 20, 2009 | 07:58 PM
cobra232's Avatar
cobra232
i addressed this in PM's but figured i would share.
the seriesI is OBDI in 91. the seriesII is OBDII so the entire wireing harness and ecu would need swapped. most likely custom axles. best bet is find a supercharged series I car and take the engine,trans, and ECU MAF from it and swap it in. everything except a few pigtails will work. those old 440t4 transmissions are not known for strength i smoked 3 on my old reatta and lesabre T-type. the supercharged cars had alittle stronger trans internals but still not great.
older 3800 series I's had the M62 blower and i believe 92+ had the m90 205hp and 225hp respectively if my memory serves me right but torque is near 300ftlbs like the supercoupe engine. if the parts can be found cheap which they should be it should be an OK swap
the series II swap would be more work than it's worth
Old Jan 20, 2009 | 08:32 PM
newpony's Avatar
newpony
ok so a s1 swap is ideal
is it a direct bolt up
(engine and trans
Old Jan 22, 2009 | 07:09 PM
cobra232's Avatar
cobra232
(engine and trans
yep
a few pigtails on the wireing harness may need swapped
Old Jan 22, 2009 | 07:15 PM
mustangman02232
whats is a l67
what car is that in
a GTP (supercharged) motor
mackstang99's Avatar
mackstang99
you could look into like a bonneville... i know that they are the 3800.. and i do believe the same platform
Old Feb 2, 2009 | 09:20 PM
newpony's Avatar
newpony
what cars dose the series 3 come in
wishinsky
Nov 28, 2012 08:16 PM
newpony
Apr 6, 2009 08:26 AM
olvanish
Nov 4, 2007 11:36 AM
MCFAST
SVT Forums
Jan 10, 2006 01:10 PM
