ITS ALIVE!!! After about 5 months of tedious work its running. Yes i love it even thou it is a 4 cyl motor. It seems like the back brake right side it dragin any advice.
First check to see: Lift up the corner and see if it turns. If it is pull it apart and look for damage, bluing of the drum shows dragging. Check the return springs and the piston. Also check your adjustment. Good Luck!! <edited><editID>Glengemen</editID><editDate>37934.4950347222</editDate></edited>
