Exhaust Leak Fixing...
So I've had this problem on and off for like a year. Scraping/hissing noise, usually terrible on cold starts and weather, not so bad once the car warms up, occasionally it's not there, but usually it's pretty noticeable. Goes away or almost totally away when the car gets all warmed up.
I'm thinking exhaust leak.
Now, the problem is that it's somewhere in the header/down pipe area. of course... the expensive area to fix. My predicament is that there's like a 50/50 chance I'll be getting rid of it come summer. But it's a crap shoot.
So. To fix my exhaust. To replace the headers and midpipe which has to be catted because of inspection, is gonna cost like buttloads.
What's the cheapest and best way to fix my exhaust front to back, and how much will it cost me?
that's expensive though... I'm thinking I could get a GT takeoff and then see if that solves the problem. I could probably get that for 50 or 100 bucks. And then if that doesn't fix it, get new headers.
Of course I'm also tempted to say screw it and let the next owner do what they wish with the exhaust, because it will probably be another 16 year old kid.
Gt and V6 cat assy's are different, the common leak point is between the two pass side cats, would need to be welded, and it's stainless steel, so the shop needs to have that ability. It cost me @100 bucks to have it pulled and welded at the local muff shop.
I had the same problem. My passenger manifold cracked. By the time i could afford to fix it the bottom flange that connects to the piping had completely severed. At this time my drivers side manifold managed to get a leak as well from where the far top flange connects to the heads. Needless to say the sound was BADDDDDDD. At that point I bought some aftermarket manifolds, flowmaster 40's and magnaflow tips and had my divorced duals finally set up with shop fabbed H pipe
cost a total of 225 for install, 160 for mufflers, 75 for the tips and 90 for the manifolds.
Forgot to mention that I first tried a cheap fix by having a mechanic weld the cracks but it just came back a few months later. Save up the money, do it right, and add a dual setup while you are at it to save future money.
cost a total of 225 for install, 160 for mufflers, 75 for the tips and 90 for the manifolds. Forgot to mention that I first tried a cheap fix by having a mechanic weld the cracks but it just came back a few months later. Save up the money, do it right, and add a dual setup while you are at it to save future money.
cost a total of 225 for install, 160 for mufflers, 75 for the tips and 90 for the manifolds.Forgot to mention that I first tried a cheap fix by having a mechanic weld the cracks but it just came back a few months later. Save up the money, do it right, and add a dual setup while you are at it to save future money.
Here's my link.
https://youtu.be/zBdFKlVRh48
FYI. it's an Amercan idea.
trashxtrash
Sep 20, 2015 10:49 PM
Sep 10, 2015 08:39 PM
