What does it mean when...
Old Mar 6, 2009 | 04:16 AM
cominus's Avatar
cominus
Default What does it mean when...
...there's alot of dirt and oil under the oil pan?
Old Mar 6, 2009 | 05:35 AM
Xemeth's Avatar
Xemeth
Oil is leaking. Look up at the engine from underneath and look for the highest spot that oil is. That's where it's leaking.
Old Mar 6, 2009 | 10:56 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
get some simple green and clean it really well, try to remove all traces of oil and grease. Then check it every few days and the leak will appear. It's common to get some spray on the oil pan from the front timing seal on the crank, but if you don;t clean the little mist every now and then, it can end up looking a lot worse than it is.
Old Mar 7, 2009 | 03:47 AM
NeoTokyo's Avatar
NeoTokyo
+1 Ryan
My 2000 engine is almost new and does the same thing, doesnt lose oil just mists it back a little sometimes.
GTV8
Jul 14, 2010 11:36 PM
cheftjpeck
Feb 26, 2008 01:12 PM
sa96vertgt
May 17, 2007 11:21 AM
