Acetone in Gas Tank?
Old 03-09-2009, 11:59 PM
robinson209
robinson209's Avatar
Default Acetone in Gas Tank?
has anyone ever heard of putting acetone in your gas tank? It's supposed to increase gas mileage. Just read a huge article on it.....
robinson209 is offline
Old 03-10-2009, 03:18 AM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
It's an urban legend. Nothing has been proven beyond a reasonable doubt, don't waste your time.
RyansQuick6 is offline
Old 03-10-2009, 08:41 AM
Archion
Archion's Avatar
There are no truly good additives that are safe for anything other than old cast iron carburated engines, they will just eat your injectors/valve seats/heads/ etc. In fact they can be so dangerous if not mixed properly, I will not list them here.
Archion is offline
Old 03-10-2009, 01:29 PM
cobra232
cobra232's Avatar
acetone is a short chain highly volitile low energy content hydrocarbon. it would be impossible for it to increase mileage cause it has less energy/molecule than light gasoline.
adding mothballs to your tank can help alittle for antiping but since naptha sublimes it doesn't mix well with liquid gasoline. only a small percentage will mix with the gas and the rest will escape when you open the gas cap again
cobra232 is offline
Old 03-10-2009, 03:16 PM
mustangman02232
mustangman02232's Avatar
snake oil..... i run ATF in my DD tho
mustangman02232 is offline
Old 03-10-2009, 07:29 PM
rfcsoulja
rfcsoulja's Avatar
You put ATF in your gas tank?
rfcsoulja is offline
Old 03-10-2009, 07:32 PM
mustangman02232
1990 Ford F-350; 4x4, 7.3 IDI diesel, E4OD, 3.55
Old 03-10-2009, 09:17 PM
RyansQuick6
Reverse Gear Member
I'm about to run a couple quarts of ATF through my engine. I wanna do a really good flush. I just hate having to buy a million quarts of oil and a hundred cases of filters to flush it out lol.
Worked great when I did it to my parents old farm truck suburban. That thing blew smoke like you couldn;t believe from it all seeping past the rings, but once it was all cleaned out and flushed good, it ran like a champ, even at over 200k
Old 03-10-2009, 10:58 PM
robinson209
so what should I put in my car? Snake oil?
Old 03-10-2009, 11:35 PM
ESG-642T
Buyer Beware
ESG-642T's Avatar
NOTHING
other than gasoline.. and oil..
ESG-642T is offline
Quick Reply: Acetone in Gas Tank?
