auto with 4:10's Help!!!!!
well something did happen a while back , i went down a strip near my house and this was before i got the gears. and what happend was i was going about 75 , 80mph and i put it in neutral to help slow it down ( at the time i didnt know thats not good to do) and i forgot i already had it in neutral when i shifted it again into reverse it started studering for about 5 sec then it cut off the engine , is that the problem?
well something did happen a while back , i went down a strip near my house and this was before i got the gears. and what happend was i was going about 75 , 80mph and i put it in neutral to help slow it down ( at the time i didnt know thats not good to do) and i forgot i already had it in neutral when i shifted it again into reverse it started studering for about 5 sec then it cut off the engine , is that the problem? after that happend it worked ok i didnt really feel anything different after that .
oh yea it will shift normally like going to the store and stuff its only when im trying to top out the car out on the highway the mph will be at 90 and the rpms are almost at 6000 and i always back off cause it doesnt feel like its gonna shift .
well Shifting into N to slow down is ok as long as you dont do it when on the gas.BUT shifting into rev when moving forward Can mess up transmissions very ez.If you go out there right now and just get in it and drive does it shift at lower rpms into 4th. if it does push the Od button off and see if it shifts down
