I had a new tlok and gears from AM put on in January and they were beautiful. After the drop I got a pretty good whine from the angle but now the whine is very irregular. If Im going 20-30mph I can actually feel that something is bent. Im still running new 225/55's on the rear but they are stiffer than the stockers. I dont see how I could have bent a rim or anything on those tires and I dont take any potholes at all. I dont rip on it and barely have enough hp to even bend anything in the first place. Just a couple mods and bilsteins with H+R super sports. What could possibly be bent?? Its drivibg me nuts.
measure driveline angles and make sure that your operating angles are no more than 3 degrees and that the u-joint angles are within 1 degree of each other. i dont think that you could lower a mustang enough to screw up the driveline angles that bad. there just isnt enough change.
when's the last time you got an alignment or had your tires balanced? I find it VERY difficult to believe you bent an axle without physically damaging it.
