Gas Saving Mod?
Old Apr 16, 2009 | 06:37 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Originally Posted by l_shizzle_l
Or you can recover lost power through the drivetrain. Thus the purpose of pulleys.
Just thought of another one, aluminum flywheel...
Too bad I said <add> and not <recover> ...
Old Apr 16, 2009 | 09:46 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Originally Posted by robinson209
Ryan you have a aluminum driveshaft right? Where did you buy it? I can't find one for the V6's anywhere....
Any 99-04 FRPP driveshaft works, autos just have to reuse the front yoke from the stock driveshaft. I got mine used.
Old Apr 16, 2009 | 09:53 PM
mvandeusen's Avatar
mvandeusen
all the $$$ you're pumping into mods to save a dollar here and there isnt worth it... is it really worth it to you??? It's not like you're going to go from 16-18 MPG to 30 MPG ... try driving 60 MPH all the time with your windows down...its simple
Old Apr 16, 2009 | 10:07 PM
jthorn9's Avatar
jthorn9
The Godfather
I agree, you're dumping a lot of money into a car to get maybe a two mpg boost "AT BEST" for which it will take a long time to get your money back on. You've already done all the basics, about the only thing left to do would be to lighten the car, but then again, without going to the extremes, it's hard to shed enough weight to truely make a difference.
Old Apr 16, 2009 | 10:32 PM
robinson209's Avatar
robinson209
How am I blowing my money? I've gotten a decent amount of power and MPG's with all my current mods. I think a driveshaft is another excellent addition. Hardly a waste of money for all those mods. You're getting a great combo of performance and economy with those.
Old Apr 16, 2009 | 10:39 PM
rfcsoulja's Avatar
rfcsoulja
Wouldn't the windows being down increase drag, thus lowering you mpg?
Old Apr 16, 2009 | 10:45 PM
jthorn9's Avatar
jthorn9
The Godfather
Technically any mod that frees up airflow, in/out the engine, will allow for more MPG (till a certain point) because the engine is working less harder to make that power at any given RPM, that's right, an S/C can actually improve MPG, however, the problem comes in when you romp on it, more power also equals more fuel delivery (till you reach 80% load, which means upgrading the fuel injectors and pump), which in turns means lower MPG. It's one of those things, yes you can do better, but at what cost when you have fun with your mods.
I just did a head, intake, and full fuel system upgrade on the 5.0 and I'm actually getting better MPG now, than before, key is, I fixed a lot of problems with the engine during the build, and I don't really romp on the gas that much. I'm maybe only getting 1 MPG, but if I dare romp on it, and force my car to run those rich 11s and 10s it runs in the a/f department, not to mention I have 30lb injectors, it doesn't take a genius to figure out the end results.
Old Apr 16, 2009 | 10:59 PM
ayrton02's Avatar
ayrton02
Control of the right foot is probably the best gas saver. I have an auto and only get around 18-19 mpg in town... I have little control.
Old Apr 16, 2009 | 11:36 PM
ramoyer1's Avatar
ramoyer1
If i want great or even good mpg i will buy a honda....I get MAYBE 200 miles to a tank
jthorn9's Avatar
jthorn9
The Godfather
Best gas saving mod availible.
