Alternator Removal
Old May 4, 2009 | 07:18 PM
Tempestshade's Avatar
Tempestshade
Default Alternator Removal
I have looked all over the internet for this, and just cannot figure out an answer.
I have a 1994 Mustang V6 Automatic.
I am attempting to remove the alternator so I can have it tested. But that is not the problem, my problem lies in the tensioner. I do not understand how to release the tensioner so that is raises and releases tension on the drive belt.
How do I do this? What bolt am I looking for? Provide a picture if possible?
I understand that I could basically 'pry' it up with a crowbar of the like, but I want to do it the proper way. It is a 94 and the engine has been neglected so some bolts are seized, anyway to unseize them?
Thanks,
David
Old May 4, 2009 | 08:02 PM
mudvayne1's Avatar
mudvayne1
WD40.
Just put a socket on the nut and pull the tension out of the belt.
Old May 4, 2009 | 08:04 PM
Tempestshade
lol, Yea but what nut? What size should the nut be? And I have put all my muscle into the nut that is on the tensioner and it does not move. Perhaps a picture with an arrow indicating exactly what nut your talking about would help?
Thanks,
David
Old May 4, 2009 | 08:11 PM
mudvayne1's Avatar
mudvayne1
Don't take the nut off the pulley. Pull the whole tensioner with the ratchet. Just lube the hell out of the whole assembly.
Old May 4, 2009 | 08:13 PM
Tempestshade
ohhh, ok so the tenersioner will actually move if I haul on it upwards, no need to remove the nut?
Old May 4, 2009 | 09:01 PM
ayrton02's Avatar
ayrton02
Correct.... use a breaker bar if you have one.
Old May 4, 2009 | 09:41 PM
stangant's Avatar
stangant
if you have any strength at all u can just pull up on the tentioner pully. the place were the 3/8 breaker bar goes broke on mine.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
