Blown Shock?
Old May 12, 2009 | 01:45 PM
eddiev22's Avatar
eddiev22
Default Blown Shock?
Whenever I go over bumps or push down on the front passenger side fender it makes a squeaking sound as if there is a blown shock? that's what i am guessing. If so it's time to upgrade but id rather spend the least as possible. Anyone have any suggestions?
Old May 12, 2009 | 02:13 PM
Fink's Avatar
Fink
Does it squeak when you turn the wheel? It could be a bad ball joint. I had the same problem and change my ball joints this morning and no more squeak.
Old May 12, 2009 | 03:05 PM
eddiev22's Avatar
eddiev22
Yes! but i figured that was either the PS pump or the serpentine belt that needed replacing? The squeak is terrible.. lol
Old May 12, 2009 | 03:10 PM
liqwidsilver's Avatar
liqwidsilver
I got the same problem its the ball joints
Old May 12, 2009 | 03:29 PM
eddiev22's Avatar
eddiev22
Nice, gona do some research on that, did you have any problems that I wouldn't foresee?
Old May 12, 2009 | 03:53 PM
eddiev22's Avatar
eddiev22
Hmm... called a mechanic and he said i should come in for a check, they would put the car on a lift and see if theres any play on the front end. It could be a number of things from the ball joints to the steering rack. Guess I'll have it checked first, but that will be in about a week so i will let you guys know whats up. im sure other people have had this problem.
Old May 12, 2009 | 03:54 PM
Fink's Avatar
Fink
No I had no problems except for a bad alignment.
Old May 12, 2009 | 06:24 PM
.boB's Avatar
.boB
Shocks and ball joints don't generally squeak when they go bad. They can, but not generally.
Disconnect your sway bar and see if the noise goes away. If it does, grease the bushings with synthetic grease and put it back together.
Old May 13, 2009 | 08:05 AM
TurtleSLow's Avatar
TurtleSLow
mine did squeek. really bad actually, turning the wheel and over bumps. i replaced my ball joint and it was perfectly fine
Old May 13, 2009 | 08:09 AM
Fink's Avatar
Fink
If it is your ball joint that is bad make sure you get one that you can grease. Both of mine were shot and I can actually grease something on my car now
