95 V6 O2 Sensor location
That would be the front driver side o2 sensor which is easy to replace(7/8's if I remember correctly). The passenger one, you will need the special socket(there's just noway to get in there), it's like 10 bucks and well worth it(or rent the kit like i did from kragen, and return for full refund). You will need to remove the passenger tire and remove the o2 sensor through the suspension parts(through the a arm, you will see what I mean if you change both sides, which is recommended). The other 2 after the cats don't normally go out, it's the front two. GL
Also, always disconnect the negative side of the battery when working on electronic parts, it will also clear the code.
Now that I think about it, I am WRONG, it is on the passenger side, MY BAD, you will need the tool for that side. I just did the wires awhile back and I remember the #1 cylinder IS in the front passenger, swap over the sensor to the other side. I would of changed both of them, but sometimes money is tough to come by, rough economy these days, or you are just CHEAP like my brother.
jwog666
Dec 27, 2021 08:09 PM
TfcCDR
Sep 14, 2015 12:08 PM
