error code?
Old Jun 19, 2009 | 08:16 PM
lil 98's Avatar
lil 98
Default error code?
okay so recently my check engine light came on and stayed on..i got it read and the code p1443 came up. iv dun sum research and have figured out it has to do with the evap system but i wuz wondering if you guys got sum input on it..like what to check and where and what i wud need to fix the problem.
thanks in advance guys!
Old Jun 19, 2009 | 10:41 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Check your gas cap
Old Jun 20, 2009 | 12:13 AM
Xemeth's Avatar
Xemeth
I doubt it's the gas cap. A gas cap will usually throw a p0440, p0442, or p0445, which are EVAP leak codes.
P1443 is a code Ford uses for the EVAP system. With a quick google search, I found that the most common problem when this code is set is a bad purge valve.
Old Jun 20, 2009 | 12:52 PM
lil 98's Avatar
lil 98
i went to napa and got a new purge flow sensor and put it in. erased the code and its goin fine now
Old May 17, 2010 | 07:39 PM
bampaslittlegirl's Avatar
bampaslittlegirl
I am having the same problem now. Do you just purchase a purge valve or is it called something else?
Old May 18, 2010 | 08:03 AM
bampaslittlegirl
And is this something I can do myself or have my dad do, or does a mechanic have to do it?
Old May 18, 2010 | 08:10 AM
Fink's Avatar
Fink
From what I just read it is a DIY job to change the sensor. I believe it is just a sensor on a vaccum line so it should be easy to change yourself.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
ChampInSD
Oct 2, 2015 04:55 AM
