Project "Under Pressure" has commenced!!!!
Didn't work on it at all yesterday, got back from Houston and had to watch the LSU game, then went straight to sleep. Got up this morning and made a run to the junk yard to get a new IAT connector since I can't find my other one anywhere. Finished routing all the vacuum lines and installing the IAT. Gonna have to trim some of the bolts holding down the S/C that are hitting the front fuel rail blocks.
About to take out the fan to install the 42% UDP. Not gonna redo the IAC jsut yet, gonna just run with no hood to the tuner and do the IAC tomorrow afternoon or saturday.
All that's left that I HAVE to install is the boost gauge, and I may go ahead and hook up the EGT. I have to also make a block off plate for the S/C mounted IAT and a bracket for the coil pack.
Once that's all done, I'm taking it all apart, cleaning everything and puting all the new gaskets in get a belt, fill the coolant and change the oil an it should be ready tonight.
