P0401 Exhaust Gas Recirculation Flow Insufficient Detected
Old 05-07-2010, 05:21 PM
robinson209
robinson209's Avatar
I'll take a look at those tubes this weekend. Thanks for the advice. I'll post back with results when I'm done.
robinson209 is offline
Old 05-08-2010, 12:19 AM
neo8222
neo8222's Avatar
Originally Posted by Derf00
That is not an option in Cali. He'll get an automatic fail when they hook up the OBDII computer to his car...
Did you actually clean the EGR valve or tubes before you replaced the DPFE sensor or did you just replace it and move on? If it keeps coming on after a few months you're probably getting carbon build up in the EGR tube that until it's cleaned out, will keep throwing the code. Being that you are in cali you will have a car with A.I.R. Tubes. These are aluminum tubes connected to the exhuast manifold on each side of the car. Each tube is connected facing the front of the car.
Pull them off and I bet you have a boat load of carbon build up on them. Clean them out and then that should get rid of your problem. I had a 2000 V6 and that was the problem I had.
whoops didnt see the cali thing lol yeah +1 to checking for carbon build up, clean out the actual EGR valve too when i took mine off it was caked with carbon build up
neo8222 is offline
Old 05-22-2012, 05:52 PM
Kathy B
Kathy B's Avatar
Angry EGR Valve replaced & getting new P0401 Code
Originally Posted by robinson209
The check engine light just came on with the P0401 Exhaust Gas Recirculation Flow Insufficient Detected. How do I fix this?
I just had the EGR valve replaced last Tuesday and the engine light came on Friday morning - with this code......I was able to reset it so the check engine light is off but did they mess something up with the repair
I hate going to a repair shop and getting the run around when it is assumed I know nothing (which I admit I don't) but I like to find out
Thank You
Kathy B is offline
Old 05-23-2012, 05:41 PM
JKs95stang
JKs95stang's Avatar
Good advice Derf, and yes don't delete, you won't even pass a quick scan of o2's, egr, and cats, a "reset" won't work, those days are LONG GONE!!
JKs95stang is offline
Luke9222
10-22-2015 11:55 PM
algregory
09-11-2015 11:44 AM
09-10-2015 08:39 PM
robjh22
Suspension
09-08-2015 12:47 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: P0401 Exhaust Gas Recirculation Flow Insufficient Detected
